-   -   T-350 Valve Body Bolt Question (http://www.hotrodders.com/forum/t-350-valve-body-bolt-question-231492.html)
zardiw 04-04-2013 03:18 PM
The book says 18 bolts......I only got 17 but I might have misplaced one while making the 2 studs to put it on.
Now there is one open spot.......and it shows threads in the case.......BUT the casting would prevent nice flat seating of the bolt head.
Any advice/info on this......I COULD get a thin washer that would mold to that casting bump:
Don't remember if there were 17 or 18 bolts when I took it apart.....:(
http://images.investorshub.advfn.com...ValveBody1.jpg
z
zardiw 04-04-2013 03:50 PM
Answered my own question.......anyway....turns out I didn't misplace the 18th bolt.....it was attached to the rooser comb spring in a baggie.....
What I DID do though is grind a little off the bottom corners of that bolt so it would seat square.
z
