T-350 Valve Body Bolt Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 02:18 PM
The book says 18 bolts......I only got 17 but I might have misplaced one while making the 2 studs to put it on.
Now there is one open spot.......and it shows threads in the case.......BUT the casting would prevent nice flat seating of the bolt head.
Any advice/info on this......I COULD get a thin washer that would mold to that casting bump:
Don't remember if there were 17 or 18 bolts when I took it apart.....
z
Old 04-04-2013, 02:50 PM
Answered my own question.......anyway....turns out I didn't misplace the 18th bolt.....it was attached to the rooser comb spring in a baggie.....
What I DID do though is grind a little off the bottom corners of that bolt so it would seat square.
z
T-350 valve body jasonhnova Transmission - Rearend 3 10-19-2012 06:42 PM
Valve cover bolt question. rajsid Engine 3 06-13-2009 09:58 PM
New 350 valve body vs 350 Valve body reprogramming kit terminator0723 Transmission - Rearend 4 04-14-2009 07:41 PM
T-350 Valve Body Rebuild Question jnobody Transmission - Rearend 2 04-02-2009 05:05 PM
Valve Body Question Bobwee Transmission - Rearend 4 09-16-2007 07:21 PM
