Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-350, what happened to engine braking?
Old 10-28-2012, 09:10 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
you will lose 3rd gear next. You can upgrade to the 400 if you dont mind the H.P. loss. My 80 Camaro ate a couple t-350s so I put a 400 with manual shift body and never had a problem.The cost is only a few dollars more than a 350.move the cross member back 2 inches.Hope your exhaust is not an issue?
