T-350 Whine in Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 01:41 PM
T-350 Whine in Gear
Hi All,
I recently acquired a '68 El Camino with a small block and TH350 trans. The trans has a whine when in reverse (sitting still or moving) and in drive (only when moving).
The sound of the whine does get higher-pitched as speed increases.
Is it possible the trans was run with too little fluid, thus causing the pump to wear prematurely?
I have another trans I could install, but if this one's OK or can be repaired relatively easily, I'd like to keep it with the car.
Thanks in advance.
Jarrett
Old 06-16-2011, 09:58 AM
My first thought is that the pump got damaged, but you need to check the fluid level first. When was the last time the transmission was serviced?
Old 06-16-2011, 11:27 AM
I'm thinking the pump may have been damaged as well. The fluid level is OK now, but still whines in gear.
I haven't a clue as to when the trans was serviced last, as I just purchased the car a couple of weeks ago.
I plan on changing the fluid and filter, maybe even flushing. Reckon that would help any?
Old 06-16-2011, 11:58 AM
Maybe. I learned this from a transmission guy, depending on the condition of the transmission, doing a flush and fill with fresh fluid could wipe out the clutches because the detergent content got restored. It's risky.
If you can get a trans shop to do a pressure check, it'll tell more than anything else.
But my personal feeling is that the pump got messed up.
Old 06-16-2011, 04:31 PM
SSedan64's Avatar
Does it make the sound in Low/1?
Just wondering if the Low/Reverse roller clutch could be causing the wine.
Pressure test Port location & Info>> http://th350.netfirms.com/pages/7a2-02.jpg
Old 06-16-2011, 10:20 PM
The sound seems to occur in all forward gears only when the car is moving and not at all when sitting still. When in reverse the noise is audible sitting still or rolling.
The sound seems to become higher pitched as speed increases.
Thanks for the replies,guys. If anyone has more insight I'd like to hear it.
I'll probably pay a visit to the transmission guy once I get to that point. If the repair wouldn't be too awfully expensive I'd like to keep this trans in the car.
Old 06-17-2011, 02:02 AM
SSedan64's Avatar
Maybe Crosley etc.. will chime in with more Info.
The Low/Reverse roller clutch is free wheeling in all gear positions (R, D, & L2) except when in D1 & Manual L1 gear position, In D1 & L1 it's Locked/Holding. Just trying to narrow the wine down.
Old 06-17-2011, 05:44 AM
Just to rule it out; did you check the rear differential?
Old 06-17-2011, 07:05 PM
whine
that whine is most likely a bad torington bearing in the rear planetary ive seen it before
Old 06-18-2011, 03:39 PM
I appreciate the clarification, SSedan64. I'll definitely go thru the gears to see if the sound persists.
cleanspeed1: I initially thought it was the rear, but when I found that the whine happens when the car is not moving I thought I could rule that out.
Thanks for everyone's response. I'll update once I determine if it's whining in all gears.
Old 06-19-2011, 08:45 AM
tnsmith10's Avatar
when will it rain???
it seems like your trans has 2 internal problems. first, getting a whine in gear only would indicate the torque converter. if it was the pump, the noise would also be present in park and neutral.
the 2nd issue is as mentioned above, theres a good chance that a planetary in the trans is failing. but yet also, the converter will make noise through all gears too, and get higher pitched with speed.
either way, it seems that its time to have the trans dismantled and rebuilt.
TH-350 whine S10Fan Transmission - Rearend 1 08-13-2012 10:06 AM
350 turbo whine stanjr41 Transmission - Rearend 5 07-04-2009 12:25 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
700R4 whine while in gear only UnionWrkr Transmission - Rearend 10 08-03-2004 01:32 PM
richmond gear whine ELFEGO BACA Transmission - Rearend 3 12-09-2003 08:29 PM
