T-350 wont go into gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2012, 03:56 PM
N someone give me an idea if i need new tranny ... Th350 .. Reverse works fine but when i put into any forward gear it acts like its in neutral ... I have checked fluid (fine) ... I noticed that vac line from carb was flattening out when engine running ,,, changed line ,, no avail .. Could it be bad modulator? Someone also told me filter .. Wouldnt those affect reverse as well ... Help please
Old 11-03-2012, 04:22 PM
Crosley's Avatar
Wiki Edits: 1659
you are correct. If reverse works fine, that indicates there is enough main line pressure to operate the trans. Reverse operation also indicates the engine power is transmitted to the trans via converter and input shaft
IF the trans will not move forward in 'any' forward gear including manual 1 . The forward clutch pack is not operating for some reason.
Is this an old trans or fresh or junk yard unit?
Old 11-04-2012, 04:09 AM
This is an older transmission ... I noticed before this happened that it was shifting at higher rpm ... Seemed like it didnt want to shift when it was in drive
Old 11-06-2012, 02:43 PM
Does you shift cable have alot of play to it? I had one where the rooster cone nut came loose on the inside and I couldnt hit P/R. I had N/D but because it got so loose it would not move to P. I swore my tranny was shot until I got a little advice from here. 11/16 wrench and about 10 mins of time. Plus if you drop the pan, install a drain plug so you never have to worry about juggling all that tranny fluid in a pan. Just something to check into.
my 350 trans wont shift out of 1st gear 86montecarlo Transmission - Rearend 2 04-25-2011 07:26 PM
my c-4 transmission wont go into gear 85stangboy Transmission - Rearend 9 02-27-2005 10:47 AM
starter gear wont go back montea Engine 4 03-18-2004 03:55 PM
HELP PLEASE,tranny wont go into gear..... Rubberman2003 Transmission - Rearend 6 06-08-2003 12:02 PM
Turbo 350,Wont downshift into Low gear when in Drive Mathesar Transmission - Rearend 4 11-08-2002 06:11 PM
