T-350c ; bad governor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2012, 06:38 PM
prettyboyced's Avatar
i have th350c i just put a new 4k stall in and now i cant shift out of 1st. when i try to shift manually to sec the motor bogs and the tires brake. i took the governor out and the gears look a little chips on the side and the top part is cut on what side but its a perfect cut i dont know is this how it comes from the factory
Old 08-04-2012, 07:05 PM
bigdog7373's Avatar
Of course it's fast
Motor should never bog with a 4k stall in there. What do you need such a loose converter for?
Old 08-04-2012, 08:30 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Sounds like you might have the wrong torque conveter.
IIRC the standard 350 conveter wont work with a 350c trans.
Probably is not ported correctly and applying the 1-2 band and direct clutch at the same time. Just a guess.
Fact is stranger than Fiction
Old 08-05-2012, 05:32 PM
It's a custom built converter I got made for th350c
Old 08-05-2012, 07:48 PM
LATECH's Avatar
I can only assume the trans worked OK before you changed the converter. IDK . Assuming this I would say the converter has a hydraulic leak bleeding over causing the issue.
Old 08-07-2012, 08:39 PM
Does the gear on the governor spin cuz mine dont
Th350 Governor bodie filyaw Transmission - Rearend 2 02-16-2011 06:58 AM
governor litldawg Engine 2 01-19-2008 08:47 PM
governor help 66novaht Transmission - Rearend 6 12-01-2004 07:27 PM
S10 Governor S10krazy General Rodding Tech 0 11-14-2003 11:22 PM
Governor? mr_josh Transmission - Rearend 11 09-05-2003 08:15 AM
