T-350C. Deep 3rd Gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2013, 06:55 PM
Car is a 83 Camaro with a unknown 350 swap and a th350c.
First off the lockup is not wired up, there is nothing plugged into the connector.
So about a week ago, I noticed after a 0-80 pull that the car sounded had a more deeper exhaust tone, and the trans has started acting like its going into overdrive in 3rd gear.
Closest thing I can explain on how it feels is having a manual car and doing a rolling start from 4-5th gear. Meaning the car will slowly creep up the Rpms but when given a quick blip of the gas, it snaps out of it and goes back to normal. This seems to only happen when under 40mph and keeping it around 1800-2000rpm. Rpms drop to 1500ish.
Other than that, the trans shifts fine manually. Fluid is at the right level.
Any ideas? I really like the gearing of the th350, enough to keep me away from a 700r4 but this might just seal the deal on the swap.
Old 03-30-2013, 03:32 PM
might be i would watch the tack let off the gas rpms shouldnt drop at all or very few what gears and tires are you running? rpms at 65?
Old 03-31-2013, 11:39 AM
Wont the TCC unlock once you let off the gas?
A test would be to get up to speed, then while holding the accelerator steady with your right fott, lightly press the brake with your left foot. If working properly the TCC will unlock, and the tach will go up 200-300rpm.
Since you dont have the TCC wiring hooked up to the trans, I doubt the TCC will function. IIRC, there is a 4 blade connector with only 1 of the slots actually used on the 4 prong connector.
Here is a diagram for the lockup function for the th-350C. My above test keeps the vacuum switch closed, but opens the brake switch forcing a TCC unlock.
here is a pic of the connector on the trans, this is actually for a th700r4 and uses 2 pins, but IIRC the th350c uses only 1 single pin of the 4 pin connector.
peace
Hog
Old 04-02-2013, 06:40 PM
is your kick-down cable connected? i would make sure your vacuum modulator is working correctly too.. sounds like that 350 is just shifting far to early.
I think you should swap to the 700r4.. but that's just me.. I made the swap in my '72 monte carlo and have never looked back at the th350c
btw.. you can use a toggle switch for that TCC control.. just remember to switch it off when you come to a stop lol.
Old 04-03-2013, 10:22 AM
He wants to stay with the th350 as he prefers the gearing. I do to as a Camaro is about 3-4 tenths quicker in the 1/4 mile over a th-700r4. That OD is nice for the highway though.
If OD is needed, the gearing of the 200r4 is better than the 700r4 although the parts of the 200r4 are smaller than the 700r4.
peace
Hog
Old 04-08-2013, 09:58 PM
Kickdown is good. Replaced the modulator a few days ago and problem is still there. Tweaked the modulator and shifting has improved but the drag down is still there.
Like I said, lockup is not connected or even anything for it is on the car to be exact.
Only way I can explain on how it is is pretty much imaging going from 1st to 3rd and the car having to climb the rpms slowly to get upto speed.
Tweaking the modulator helped abit, to the point the rpms drop isnt as dramatic as before but it just really drags giving it gas and having it climb up/gain speed slowly. Downshifting to 2nd and back to 3rd snaps the car out of it and it acts like normal.
My next step is doing a simple filter and pan drop...
Old 04-09-2013, 09:38 AM
OK, so as you start out from a stop, the trans goes into 3rd gear too quickly causing your acceleration to be boggy.
If you start from a dead stop with the gear selector in 1st gear, then get up to speed, then shift into 2nd, accelerate more, then shift into 3rd.
Does it work OK doing that?
This sounds like it simply going into 3rd too quicly.
Anyone help this guy?
peace
Hog
Old 04-09-2013, 11:21 AM
Yes sir the trans feels like normal if I shift it manually.
T-350C trans whines in low gear the82elco Transmission - Rearend 4 08-11-2012 04:36 AM
c4 will not shift into 3rd gear royhldn Transmission - Rearend 4 10-20-2009 10:01 PM
T-56 NO MORE 4TH GEAR, and NO 3RD GEAR SYNCOS!!! chevyelc81 Transmission - Rearend 5 12-05-2004 10:39 AM
No 3rd gear?!? Tissue Transmission - Rearend 5 11-13-2004 01:07 PM
no 3rd gear , Help chevtruck Transmission - Rearend 3 09-29-2004 07:09 AM
