T-350c, Is my converter seated? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 10:09 PM
prettyboyced's Avatar
I have a locked up th350c I'm replacing my old 2400 stall with a 4000 it's an 9' stall but I'm kinda worried if it's all the way seated I only heard 2 clunks but the converter is all the way in the pump I see no shiny part on converter
Old 08-02-2012, 11:04 PM
mud.man.rj's Avatar
convertor seated?
Sounds like you have it, is kind of obvious though with pushing and turning it and it goes in one stage then continuing does it again, one more thing though is that it will be back inside past the face of the case, not flush. If not pull out and try again. You will get it.
Old 08-03-2012, 08:26 AM
I just wanna make sure it just kinda confused me because the converter is so small and I can put my fingers between the converter and bellhousing
Old 08-03-2012, 08:35 AM
S10xGN's Avatar
Gotta love a turbo!
Straightedge across the bellhousing, measure the depth to the converter lugs. Compare that to the measurement from the rear face of the block to the mounting pads on the flexplate. First dim should be 1/8" to 1/4" greater than the second...
Russ
Old 08-04-2012, 12:05 PM
I bolted up everything but now if I try to switch from 1st gear it feels like I'm putting it in park so basically I only have 1st
How to tell if stall converter is seated chuck whitaker Transmission - Rearend 10 08-05-2012 08:03 AM
Blow-by 383 rings not seated? (video inside) sexypizzaman Engine 12 05-31-2009 09:00 PM
Be seated... 38 special Hotrodders' Lounge 5 09-14-2007 08:12 PM
stall speed converter on th-350c question tfeverfred Transmission - Rearend 9 08-12-2007 06:19 PM
Getting the window seated strummin67 Interior 8 06-09-2007 05:52 PM
