T-350C problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 02:58 PM
T-350C problems
Hi all, I have a 1981 Turbo T.A and my tranny decided to take a dump on me so I googled th350 rebuild and I found Hot Rodders (very cool name). Any and all help welcome. Thanks.
C.B
Old 08-21-2011, 03:23 PM
Chicagobob,
You ask a question about the transmission and we will answer as best we can.
Scholman
Old 08-22-2011, 02:24 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
What do you mean by "took a dump"? In my 81' 'Bird i had the tranny lines blow up in my rad filling the tranny with water and coolant, shredding my clutches. I bought a B&M rebuild kit and a shift kit $200 on Summit put it behind a 454BBC havn't had any problems since. And of course i bought a new TC.
Old 08-22-2011, 05:28 PM
SSedan64's Avatar
More Info would help. What problems does the Trans have?
Suggestions:
ATSG Manual & Rebuild Video.
Hughes Performance Rebuild kit or other brand, B&M, TCI etc.. but don't buy a rebuilt B&M or TCI Trans.
http://www.crankshaftcoalition.com/w...0_Rebuild_tech
http://www.carcraft.com/projectbuild...dup/index.html
Old 02-01-2012, 10:00 AM
i'll try this again to the best of my ability. when driving home from work my trans was making noises and a lil skipping and slipping. I made it home but around a block away the car would not move at all. Motor runs,shifter shifts and the fluid is full. I took off the bottom pan and noticed what looked like graphite, like gears that have been ground to dust. Car has been sitting ever since. Does this help?
Bob
Old 02-01-2012, 10:01 AM
I failed to mention that I took out the 301 T and replaced with a 400. The tranny in a th 350C.
Bob
Old 02-01-2012, 10:46 PM
SSedan64's Avatar
The material in the Pan is from Clutch Friction, Bushing wear etc., it builds up over time. More than a Teaspoon = Rebuild time.
Your Trans could have many problems, Torque Converter, Pump, Filter, Linkage, Seals etc..
Was Fluid level Ok? Filter plugged/stopped up?
Try doing a Pressure Test on it. Line Pressure Tap/Port is just rear of 1-2 Accumulator cover on passenger side.
Old 02-08-2012, 11:14 AM
Thanks ssedan64
th 350c? joeyb Transmission - Rearend 5 11-21-2009 10:32 AM
Turbo 350C problems White84GMC Transmission - Rearend 2 09-29-2009 07:15 PM
th 350c help malibus~most~wanted Transmission - Rearend 4 04-01-2008 02:58 PM
1986 GMC with t-350C problems twillmott Transmission - Rearend 3 03-25-2007 11:07 PM
T-350C problems NIWROC Transmission - Rearend 13 01-12-2006 01:35 PM
