T-350C Torque Converter Overheat - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2014, 09:58 AM
This is a strange one.
I have a Th350C coupled to a 350 small block. I rebuilt the gearbox myself.
I added a Torque Converter Clutch switch on the dash.
I have driven 2000 odd km's without any problems and the TCC works well engaging at around 70km/h when switched on. The internal pressure switch disengages it automatically at low speeds.
The other day, I was cruising at around 120-140km/h for the longest period yet when suddenly the trans fluid boiled over and squirted out of the filler pipe all over the motor.
Lots of smoke and a bit of fire resulted.
From the paint discolouration it looks like the heat was localised in the Torque Converter.
I have a trans temp gauge and while I was cruising with the TCC on the trans temp was lower than normal (when cruising with it off). This is what I would logically expect as the fliud coupling would not have been generating heat.
I also have a trans cooler in front of the radiator and the ambient air temp was around 10 deg C.
After the boil over I replaced the oil and continued to drive 400km's home... without engaging the TCC!
I was wondering if someone can figure out a possible cause for this. The only logical explanation I can figure out is that the TCC was slipping a bit while I was driving causing excessive heat buildup. But then again, it felt very much like direct drive to me and I am pretty astute with these feels.
Please Help,
T.
T-350c, Is my converter seated? prettyboyced Transmission - Rearend 4 08-04-2012 01:05 PM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 07:47 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 08:52 PM
stall speed converter on th-350c question tfeverfred Transmission - Rearend 9 08-12-2007 07:19 PM
700R4 torque conv makes camaro overheat J-Dog Transmission - Rearend 3 10-31-2005 09:20 PM
