-   -   T-350C trans whines in low gear (http://www.hotrodders.com/forum/t-350c-trans-whines-low-gear-222731.html)
the82elco 08-09-2012 11:20 PM
i have a th350 c trans that has been converted to a non lock up. with a 2200-2700 stall. An when i have it in low gear it makes a whining sound and it gets louder as i go faster:confused:
the california kid 08-10-2012 05:37 PM
82 elco
what's your question?
it sounds like tranny is going out.
first gear takes the most beating,
even doing burnouts with skinny tires.
the tranny does bad things when you
let off the gas, unless you pop it in neutral
near end of burnout.
even that's not a good thing.
have a nice day!
LATECH 08-10-2012 06:35 PM
T 350 GMs allways had a sound in low. Kind of like a whining or ringing.
Its usually not loud, but you can hear it easily. The planetary gear set is responsible for this.
How loud is it?
the82elco 08-10-2012 06:40 PM
How loud is it?
i can hear it over my exhaust an my exhaust is pretty loud because my exhaust is under the car
SSedan64 08-11-2012 04:36 AM
X2^^, Low/Rear planetary is probably shot if it's that loud.
#584 >> https://www.wittrans.com/Schematic.a...0C&Schematic=3
