T-350C trans whines in low gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2012, 11:20 PM
i have a th350 c trans that has been converted to a non lock up. with a 2200-2700 stall. An when i have it in low gear it makes a whining sound and it gets louder as i go faster
Old 08-10-2012, 05:37 PM
82 elco
what's your question?
it sounds like tranny is going out.
first gear takes the most beating,
even doing burnouts with skinny tires.
the tranny does bad things when you
let off the gas, unless you pop it in neutral
near end of burnout.
even that's not a good thing.
have a nice day!
The Following User Says Thank You to the california kid For This Useful Post:
the82elco (08-10-2012)
Old 08-10-2012, 06:35 PM
LATECH's Avatar
T 350 GMs allways had a sound in low. Kind of like a whining or ringing.
Its usually not loud, but you can hear it easily. The planetary gear set is responsible for this.
How loud is it?
Fact is stranger than Fiction
Old 08-10-2012, 06:40 PM
How loud is it?
i can hear it over my exhaust an my exhaust is pretty loud because my exhaust is under the car
Old 08-11-2012, 04:36 AM
SSedan64's Avatar
X2^^, Low/Rear planetary is probably shot if it's that loud.
#584 >> https://www.wittrans.com/Schematic.a...0C&Schematic=3
The Following User Says Thank You to SSedan64 For This Useful Post:
the82elco (08-11-2012)
3.73 richmond gear whines spinn Transmission - Rearend 9 01-01-2011 01:42 PM
powerglide low gear 47fordnash Transmission - Rearend 1 04-16-2010 07:55 PM
RPM to Low in gear prettyboyced Hotrodding Basics 6 03-11-2010 02:21 PM
stuck in low gear tsw5013 Transmission - Rearend 4 01-17-2006 09:48 AM
GMC diff whines cindyandsean Transmission - Rearend 2 10-24-2003 09:09 PM
