T-400 2-3 shifting issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 09:17 PM
Last fall I rebuilt my th400 myself. Noe I am far from a tranny guys but I am very mechanical. Everything went great. but I have an issue. When I go for a drive it seems to run fine for 10-15 miles then going 55-60mph the tranny will kick down to 2nd gear. If I give it some gas it will go to 3rd, and when I let off it will drop to 2nd. I have not started looking at it yet but I was wondering what to look for?
I have a MAC trans pressure gauge and hose. I have read possibly high line pressure but haven't heard how to solve it if it's the issue.
Any help would be great. Thanks guys
Old 03-08-2012, 06:00 AM
tnsmith10's Avatar
when will it rain???
kick down solenoid. its either getting energized somehow, or it is failing.
Old 03-08-2012, 11:45 AM
jakeshoe's Avatar
Actually I think it sounds like a worn governor or bore.
Measure the governor, it should be .799-.800", if it's less replace it.
It probably also has 2nd gear starts hot.
700r4 shifting issues nytetrain Transmission - Rearend 1 02-13-2012 06:26 PM
4l60e shifting issues jtalb Transmission - Rearend 3 12-06-2011 08:07 AM
700r4 shifting issues 1986c10 Transmission - Rearend 10 06-20-2011 07:28 PM
T-400 Shifting Issues cm113 Transmission - Rearend 4 10-26-2009 05:04 PM
th 350 shifting issues frankenstang57 Transmission - Rearend 2 04-20-2005 03:56 PM
