T-400 and 3.08. rpm/tire combos? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2011, 10:03 AM
Last wiki edit: Mounting an electric fuel pump Last photo:
im running a cad 425/th400 threw 3.08 rear. i have no tach and would like to know what is a safe tire size to run on it. this is my d.d. and sees 60mph+ everyday. right now i have a set of 31/12.5 r15 on it. i realy dont wana smoke this motor, its old and needs sum help but i dont have the money right now
Old 12-07-2011, 10:54 AM
Probably a 15" rim with a 26 or 27 inch tire; you'll need to calc your application to get the proper speedometer gear to dial it all in. 16 and 17" rims make it look nice, but you get into more expensive tires, decreased low-end performance and heavier rims.
Old 12-07-2011, 01:16 PM
thanks for that info. i have a realy tight budget so im not worried avout the spedo right now lol its ben off since i put this motor trans combo in. do you have ayt idea about what rpm i would b running at 60 with my combo and say 27 in tires on 15 in rims? and what would 27in transfer over to in the xxx/xxrxx system? 245/75 r15 maybe?
Old 12-07-2011, 04:41 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Google "Gear tire ratio chart" there will be several sites that pop up. Enter all of your info and determine what you think your engine will handle for rpm's @ 60
Old 12-07-2011, 04:46 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Or use one from here: http://www.wallaceracing.com/Calculators.htm
Question about tire size and rpm sexypizzaman Engine 2 03-03-2009 10:09 PM
SBC Strokers - 350 vs 400 Blocks & Combos (not just 383 & 406) ez2cdave Engine 11 05-21-2007 09:34 PM
Trans / Rear / Tire / Speed / RPM Calculator 70gs455 Transmission - Rearend 1 01-20-2004 07:33 AM
RPM, GEAR RATIO , TIRE SIZES, EQUATIONS zonk Transmission - Rearend 1 01-08-2003 10:16 AM
