t-400 for a 355 CID chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2006, 09:06 PM
400 tranny for 355 chevy
Is a 400 transmission too much for a 355 , or should I just rebuild my TH350c with steels and the reprogamming kit i have and what size stall.
Old 12-07-2006, 09:17 PM
Tranny question
So it would be better to build the TH 350c than. I have a Transmission rebuild kit I bought from Oregon performance transmission that has the steels in the kit also. I also have a transgo reprogramming kit. Would this be a better thing to do, re-build the TH350c?
Old 12-07-2006, 09:29 PM
Crosley's Avatar
Wiki Edits: 1659
BLUE82...... you started asking questions within a thread of a different subject. I split off your post to a new thread.
GM used the t-400 behind a 350 chevy small block. They work well.
Old 12-08-2006, 09:43 AM
t-400 for a 355 cid chevy
As Crosley states,the 400 works well,tough trans. If you use the 350c and your not brutal,it will do well also.Much has been posted as to how good a th350 can be.
Now one word of caution. If you use the 350c,and you want lockup to work,do not leave the center seal out of the direct drum[dual feed piston].
This is a failsafe device GM uses for the converter clutch apply valve.
