Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 4x4
Thread: T-400 4x4
Old 01-15-2013, 05:29 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by fleenorracin View Post
i got a th 400 with a 203 t case does anyone know what i have to do to change it to a 205 t case
To use a factory GM setup for a 205 t-case, you need the out put shaft for the T-400 that will match the adapter for the 205 t-case
205 t-case has an early & late design bolt up to the back end of the T-400.
Early 205 design uses a short style 2WD out put shaft with matching adapter.
Later 205 design uses a shorter out put shaft than the 2WD shaft, yet it is longer than the 203 output shaft you have now
