-   -   T-400 4x4 (http://www.hotrodders.com/forum/t-400-4x4-228427.html)
fleenorracin 01-15-2013 03:17 PM
T-400 4x4
i got a th 400 with a 203 t case does anyone know what i have to do to change it to a 205 t case
Crosley 01-15-2013 05:29 PM
To use a factory GM setup for a 205 t-case, you need the out put shaft for the T-400 that will match the adapter for the 205 t-case
205 t-case has an early & late design bolt up to the back end of the T-400.
Early 205 design uses a short style 2WD out put shaft with matching adapter.
Later 205 design uses a shorter out put shaft than the 2WD shaft, yet it is longer than the 203 output shaft you have now
fleenorracin 01-16-2013 05:09 PM
thanks for the info
snag5702 01-20-2013 09:51 AM
203 to 205
go to advance adapters they have a kit to do the job for around 700.00 bucks this is the best way to go.
