Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 '65 sprag
Thread: T-400 '65 sprag
Old 08-18-2011, 05:59 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
your part 'B' is a sprag. the next foto is a roller clutch in the Borg Warner package for the later design planet / carrier
As I mentioned , you are not going to find a new sprag type clutch for the planet. Trans parts suppliers have not stock'd them in years. You may find a supplier with a correct size sprag if you look hard enough.
The roller clutch in the carrier has been used in very high horse power applications and worked fine.
