T-400 '65 sprag
I read this article on Wiki http://www.crankshaftcoalition.com/w...0_Rebuild_tech and there is a picture, which shows exactly what I need:
![]() I have an early style reaction carrier in my TH400 and now I need a sprag, that fits into that early style carrier. (see picture - the right sprag element) Please help me find that part. (store - part number...) I bought rebuild kit for TH400 but there was late style sprag element in it. Thanks! |
sprag
you can get it from TSR racing.com
Yes, Intermediate Sprag.
34-Element: http://www.transmissionpartsusa.com/...rts_s/5751.htm http://www.transpartsonline.com/TPOT...cription=SPRAG INTERMEDIATE 400/4L80E 34 ELEMENT&Addition=null&Price=63.434&Pic=400&Variabl e=131&Core= https://www.wittrans.com/SchematicPa...0&LinkCode=652 http://www.makcotransmissionparts.co...-400sprag.html Last edited by SSedan64; 08-17-2011 at 10:33 AM. |
the roller clutch and early design sprag for the planetary units in the photo by the original poster here..... are the low sprag / roller clutch. That is NOT the intermediate sprag.. the intermediate sprag is on the direct drum.
I have not seen a new sprag for the early planet design in many years.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Whoops, Crosley is correct.
I was looking at the Direct>> http://www.crankshaftcoalition.com/w...ign_comparison I don't see that part listed anywhere either. |
your part 'B' is a sprag. the next foto is a roller clutch in the Borg Warner package for the later design planet / carrier
As I mentioned , you are not going to find a new sprag type clutch for the planet. Trans parts suppliers have not stock'd them in years. You may find a supplier with a correct size sprag if you look hard enough. The roller clutch in the carrier has been used in very high horse power applications and worked fine.
At the Bonneville Salt Flats, first gear is known as 130 mph. Last edited by Crosley; 08-18-2011 at 06:20 AM. |
Hmm, so what you suggest for me to do? Put old used part back to tranny or something else? Since I'm from Europe, it's very hard for me to find some USA supplier for that sprag.
Maybe someone from the forum can help.... About that roller clutch in the picture: I always thought that the roller clutch is the replacement for the "B" sprag. Does it fits somewhere else into my tranny? Am I missing something? ![]() I bought master rebuild kit for TH400 and everything fits except that roller clutch wich is similar size as "B" sprag, so I tought that it should be replacement for "B" sprag.
The roller clutch in your rebuild kit IS the design replacement for the sprag in the planetary unit... it IS the late design which requires the later design planetary carrier. You obivously can not use the roller clutch in place of the sprag design. The photo you posted earlier of the 2 designs of the planetary carrier indicate the designs are different and can not inter change the roller clutch into the early sprag design planetary carrier. If the sprag is in good shape, you may have to re-use it in the planetary carrier. The roller clutch in your kit does not fit any where else.
| TH400 drum and sprag in a TH350? | upstand2 | Transmission - Rearend | 2 | 06-30-2008 11:25 AM |
| T-400 34 Element Intermediate Sprag | 68NovaSS | Transmission - Rearend | 7 | 06-25-2005 10:13 PM |
| Replace sprag turbo 400 | Cruzerbobby | Transmission - Rearend | 8 | 11-20-2004 10:34 AM |
| 36 element sprag? | Marcus | Transmission - Rearend | 2 | 10-29-2004 02:39 PM |
| T-400 Sprag/Direct Clutch Checkball | 68NovaSS | Transmission - Rearend | 3 | 04-27-2004 09:10 PM |
