T-400 or 700r4 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2012, 05:53 PM
ronbuhg's Avatar
T-400 or 700r4 ?
has th400 ,isnt 700R4 better overall?? also has homemade crossmember in now..very unsafe looking. what crossmember should i get?original for 700
R4 or aftermarket??
Old 05-02-2012, 06:41 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
TH400 is a good tranny for a high performance engine.
700R4 is a good mileage tranny for low to medium output engines.
Of coarse the 4L80E is good for high power and mileage.
Got a pic of the bad crossmember?
Old 05-02-2012, 06:43 PM
LATECH's Avatar
Depends on your build/goal/funds.
Tell us more about your build. Like what car you have, engine,rear gear ratio, tire size, most important purpose of said vehicle.You want street machine? all out drag machine?
Fact is stranger than Fiction
Old 05-03-2012, 11:53 AM
ronbuhg's Avatar
yes but dont know how to post pics...duh!!! [new to computers ] anyone want to swap my th400 for your 700r4 or 4L80E ??been advised to use original crossmember & redrill holes along w/2piece driveshaft also shimming up trans mount [1 inch ] for pinion anglesthanks for advice ,will do that asap
Old 05-03-2012, 12:15 PM
ronbuhg's Avatar
85 S10 w/350 street cruiser/show truck..mild to medium power,"thumper cam "3.73 gears,more of show w/ a little go !?!want it to be reliable enough to go visit my brother in S.C. to go w/him to his local shows,etc.love all makes &models of hotrods,GM,fords,mopar,etc.my bro has a 99 roush stage 2 mustang,its midddle of med to rad.nice car! {back to my truck ]i'll need to r&r heads to upgrade to screw in studs,guide plates [ iron heads}possibly springs {?} or is alum heads better cost/ wise and/ or practical ?? another question for anyone to answer for me....B&M Mega shifter..how can it work for a th350 and 700r4 when one is a 3 spd &other is a 4spd???THANKS !!psps no trailer queens 4 me !!i'll drive it everywhere!!thats where the real fun is for me!!
Old 05-03-2012, 01:50 PM
a performance oriented 700r4 is all you need.
Old 05-03-2012, 02:05 PM
s10mannn's Avatar
[QUOTE=ronbuhg]has th400 ,isnt 700R4 better overall?? also has homemade crossmember in now..very unsafe looking. what crossmember should i get?original for 700
R4 or aftermarket??
isnt the th400 much stronger? 700r4 is an s10 tranny i believe
Old 05-03-2012, 02:29 PM
Saying something is 'stronger' is great. However this is typical hamfisted, bigger is better-ism. The TH400 takes a lot of power to turn, has 3 speeds and a pretty low (numerical) 1st gear.
The 700r4 and its newer variant the 4L60e have been used deep in the 10s and even farther.
The TH400 was used in some pickup trucks behind the 305. But if you're dead set on a 3spd non OD trans, use a TH350 instead of the 400.
A thumper cam SBC does not need a Tubbo 400; some will tell you it needs a different cam.
Old 05-04-2012, 10:36 AM
ronbuhg's Avatar
[QUOTE=s10mannn]
R4 or aftermarket??
you r correct ,but the trannny has the bolt pattern for the 2.8L.no-go there.will get the 700R4 or the other electronic version.as soon as as im out of this cast{rt ankle suffered in a "speed bump" for a jeep}i was on foot when the jeep hit me !!i know i was very lucky could have been awhole worse!!thanks for your advice !!
Old 05-04-2012, 10:38 AM
ronbuhg's Avatar
i'll go w/your advice as well as others have.thanks!!
Need opinion...700R4 or T-400 my87chevrolet Transmission - Rearend 7 11-08-2012 08:13 AM
T-400 conversion to 700r4 jllucky17 Transmission - Rearend 1 10-04-2012 05:15 AM
400 sbc. . T-400 or 700r4 blackpanther68 Transmission - Rearend 2 08-05-2012 06:32 AM
T-400 or 700r4 old west Transmission - Rearend 9 10-17-2011 11:27 PM
700r4 vs T-400 Derkyb Transmission - Rearend 8 04-04-2005 11:11 AM
