T-400 in 93 firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2011, 03:53 PM
hey i was just wondering what has to be done to swap a th400 into a 93 firebird lt1
Old 01-01-2011, 05:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What transmittin are you removing ?
Automatic or stick shift trans ?
Old 01-03-2011, 11:54 AM
th400 93 firebird
well some moron took the six speed out of it then put a 700r4 in it and it blew up typical but anyway i pretty much know what i need to do to put the th400 in crossmember drive shaft and the mount for the torque arm but is there any other cars i could get the parts off of to fit
Old 01-03-2011, 01:28 PM
SSedan64's Avatar
No, all these parts will be Aftermarket only. No factory swap parts available, except the electronic Speedo parts. Some of the 90's trucks still used the TH400, such as 1-ton models.
A few part #'s here>> http://www.turbobuick.com/forums/tra...ml#post2676777 courtesy of Donny Wang.
Waking my beast (1967 Firebird 400) Keegan Engine 2 10-15-2006 10:04 AM
68 firebird 400 convertible cadillackid Hotrodding Basics 2 02-25-2006 09:17 AM
69 firebird 400 engine heads mts Engine 10 03-09-2004 10:52 PM
which 5 speeds will bolt up to a 71' firebird 400? Chirodan Transmission - Rearend 6 01-27-2004 05:26 PM
Rear end for 67 Firebird 400 pringles Transmission - Rearend 5 10-09-2001 08:07 PM
