T-400 behind a 6.2 diesel CUCV military blazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2013, 09:00 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Having a few issues with this 1984 blazer. One of the Military M1009 CUCV jobbys with the 6.2 diesel and a TH400 trans.
It has a engine mounted vacuum pump and it's sole purpose is to operate the trans modulator valve through a 'vacuum valve' deal that is basically a throttle position sensor which is mounted on the injection pump and follows the movement of the throttle shaft.
Vac pump is working good, the 'TPS valve' is good and the modulator valve holds vacuum.
One problem is that is will not automatically shift into 1st in 'D' range but will if you select L1 range.
Another problem, auto upshifts in 'D' range is not good, it winds 1st too long and will finally shift into 2nd when you back out of the throttle a little. If you havn't wound up 1st enough it will just free wheel and not go into second remaining in first.
Manually moving the shifter it will shift ok with 1 to 2 a nice quick shift. 2 to 3 is better but still soft.
2 to 3 is very soft and will sometimes sound like it slipping.
Around a 100k miles, fluid is nice and red with a normal smell.
Old 03-14-2013, 07:12 AM
C-10's Avatar
Revolution Calling
To be more clear:
One problem is that is will not automatically shift into 1st in 'D' range but will if you select L1 range. This is after a 1-2-3 upshift rolling back down to a complete stop. Remains in 2nd gear
Old military and old racer msggator Introduce Yourself 3 11-01-2009 11:00 AM
diesel engine to gas conversion with T-400 trans RedBush1 Transmission - Rearend 16 04-19-2009 08:17 PM
Thank you to the Military OneMoreTime Hotrodders' Lounge 9 02-05-2005 07:25 PM
Military Silentlion_69 Hotrodders' Lounge 22 01-27-2005 08:57 AM
turbo 400 tranny, in a 6.2 liter diesel suburban troran Transmission - Rearend 0 10-08-2003 12:09 AM
