T-400 check balls - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2011, 12:49 PM
Last wiki edit: Mounting an electric fuel pump Last photo:
T-400 check balls
hi iv got other posts dealing with my trans but wanted to start a new one just for this since i cant realy find alot of info on it. im about to drop the v.b.on my 79 cad th400 and im sure the check balls will go rolling all over the floor. is there any way of knowing where they go and is there anything else i should know about. also i have this 79 cad th400 behind the origanal cad 425 in a 86 c10. im gunna b buying new gov, mod, k.d. solinoid form our local car quest, are all the parts the same or should i change them to better suit the much lighter vehicle?
Old 09-21-2011, 07:09 PM
Crosley's Avatar
Wiki Edits: 1659
take a look in the Crankshaft wiki:
clik here
Old 09-22-2011, 09:58 AM
clik here
ok read the entire artical. now my question is, where do they go in a STOCK v.b.? im not lookin to turn this into a race car. i just want it to work again. and u didnt answer my other questions about the parts. this sight has ben very helpfull but lately, not so much.
Old 09-22-2011, 12:57 PM
6426yy's Avatar
http://www.chevelles.com/forums/showthread.php?t=194778
heres a link that has a picture of where the checkballs go. your parts should be fine get an adjustable modulator, you may have to modify your govoner to suit your driving style, not hard install it the way it is and check it.
Old 09-22-2011, 06:34 PM
Crosley's Avatar
Wiki Edits: 1659
check balls go in the same place in STOCK unit.
Old 09-22-2011, 09:02 PM
ok thanks for clearing that up crosley and thanks for the link 6 but the pic in the link wont load. im sure its the same as in the wiki artical tho. i was able to make it into town today and order parts. fluid, filter, and pan kit in stock. BUT, solinoid coming in sat and gota wait till wed for the modulator. couldent get the gov at all. got a autozone and o'rileys bout 45 min away, dose anyone know if i can get one threw them?
Check Balls In The 4l60e ? old yukon Transmission - Rearend 5 04-27-2011 11:47 PM
t-350 check balls location ? bodie filyaw Transmission - Rearend 4 02-20-2011 04:25 PM
TH350 tranny check balls bodie filyaw Transmission - Rearend 13 02-02-2011 07:52 PM
T-400 check balls jlwagner17 Transmission - Rearend 14 06-14-2010 10:54 PM
700r4 check balls sbc400_700r4_3.42 Transmission - Rearend 6 12-11-2008 01:48 PM
