T-400 Clutch Plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2009, 03:37 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
T-400 Clutch Plates
I'm working on a TH400.
The kit comes with a set of smooth and waffled direct and forward clutches.
Which ones go where?
Thanks,
Pugsy
Old 09-04-2009, 04:21 PM
123pugsy's Avatar
Wiki Edits: 29
One more question......I've got all my parts mixed up
.....which piston has the checkball.....fwd or direct?
Also , should I turn down the piston to max out the amount of clutch plates for high performance use?
Old 09-04-2009, 04:49 PM
ericnova72's Avatar
More for Less Racer
Smooth clutches go in the forward clutch as it isn't a "shifting" clutch. The waffle pattern is there to allow fliud escape and cooling when the clutch applies during the shift.
The piston with a check ball matches the drum that doesn't have a check ball, and vice versa.
Old 09-04-2009, 05:56 PM
123pugsy's Avatar
Wiki Edits: 29
Thanks for splainin in a way I can remember.
Pugsy
Old 09-05-2009, 10:30 PM
Wiki Edits: 85
There MUST be at least one checkball for each drum. Sometimes the CB is in the drum, sometimes in the piston, or both. Just make sure that both assemblies have a CB.
Old 09-06-2009, 05:14 AM
123pugsy's Avatar
Wiki Edits: 29
Thanks.
I have one checkball in each.
I found some other old pistons on the shelf and noticed different thicknesses.
Are some designed only to hold 4 clutch plates and others designed to hold five ?
I ended up turning the pistons for this build down to fit all five.
Old 09-06-2009, 07:52 AM
Crosley's Avatar
Wiki Edits: 1659
Thanks.
Pistons are different heights and there are some drums machined for more depth.
There are thinner frictions and steels available to increase friction counts.
Performance trans should have a 6 x 6 x 3 friction count. Some I build run 7 x 7 x 4 friction counts
Old 09-06-2009, 12:37 PM
123pugsy's Avatar
Wiki Edits: 29
Can you translate those #'s to English Crosley?
Old 09-06-2009, 02:48 PM
Crosley's Avatar
Wiki Edits: 1659
6 frictions in forward
6 frictions in direct
4 frictions in intermediate
Old 09-06-2009, 04:11 PM
123pugsy's Avatar
Wiki Edits: 29
Thanks Crosley.
T-400 direct clutch problem SaM91 Transmission - Rearend 6 04-16-2013 12:33 AM
T-400, semi metallic waffle plates in stock rebuild...good idea or a bad one? Big Buick Transmission - Rearend 4 07-18-2010 08:44 PM
Do Clutch Plates and Pressure Plates Have to be the Same Diameter? mrwumper Transmission - Rearend 3 03-30-2009 12:43 AM
Cam wear plates/thrust plates jakejake1966 Engine 3 04-12-2006 03:54 AM
Decision: more clutch steel plates? darom Transmission - Rearend 10 10-03-2003 09:04 AM
