Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 conversion to 700r4
Old 10-04-2012, 04:15 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by jllucky17 View Post
Hi, I have an 86 Chevy c-10 shortbed 2wd I'm want to put a 700R4. Just wondering if it would bolt up to my vortec 350 and if I would need a long nose or a short. Also would I have to mod anything such as the tranny mount. Any suggestions as to where to purchase one also would be great.
Yes it will bolt up to the 96-99 Vortec.
There is no long or short Tail 700R4, the Vette 700R4 is slightly shorter.
Your stock Crossmember should work, slide it forward.
87-92/93 700R4 is the best to start with, has more factory upgrades.
Driveshaft may need to be shortened or Slip Yoke changed depending on what length the TH400 is.
Trans lengths & ID >> Automatic Transmission Identification
Make sure you have the correct TV Cable & Brackets and it's set properly before use. The TV cable isn't like a Detent cable or switch, it controls line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts.
TV 101 >> Bowtie Overdrives | TV Made EZ
The Following User Says Thank You to SSedan64 For This Useful Post:
jllucky17 (10-04-2012)
