T-400 conversion: 75 chevy truck 4 speed to a T-400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2014, 07:54 AM
Hellbilly Hotrods
helping a friend of mine convert his 75 chevy truck from a 4 speed to a th400. i know that there is some sort of electrical setup for the trans kickdown.
what is the easiest/most economical solution for this? these trucks just about dont exist in salvage yards in my area, so i cant just go snag stuff from the junkyard.
thanks guys.
michael
Old 02-04-2014, 02:50 PM
techinspector1's Avatar
Wiki Edits: 326
what is the easiest/most economical solution for this? these trucks just about dont exist in salvage yards in my area, so i cant just go snag stuff from the junkyard. thanks guys. michael
Hey Michael, there is a 12v terminal on the driver's side of the transmission case. When you apply 12v to it, the transmission downshifts from 3rd gear to 2nd gear.
The OEM arrangement had a switch under the accelerator pedal. Anyone who has that arrangement for sale thinks they are made of gold, so I would try to rig up an aftermarket switch that would work off the throttle linkage, such as this offering from B&M.....
http://www.summitracing.com/parts/bm...FVKRfgodkmsAPw
You should have a vacuum line from the intake manifold to the modulator and a 12v wire from the switch to the kick-down solenoid spade on the side of the transmission case. Take 12v from the ignition switch, run to the switch, then out of the switch to the spade on the trans case.
The Following User Says Thank You to techinspector1 For This Useful Post:
AutoGear (02-05-2014)
Bolt pattern from a chevy T-400 to cadillac T-400 nthogdog Transmission - Rearend 7 03-23-2011 06:05 PM
400 pontiac and 400 chevy?are they the same? 77'Omega Engine 34 07-01-2010 12:10 PM
400 pontiac and 400 chevy?are they the same? 77'Omega Engine 5 06-15-2010 05:51 PM
pontiac 400 or chevy 400 47chevrolet Engine 2 02-02-2007 02:08 PM
400 sb going to 4 speed cub Transmission - Rearend 1 04-04-2004 07:47 PM
