T-400 Cooler Lines
Noob here with some more 4oo questions. Because I have a new 3000 stall converter in this new 400, I was told to run an external cooler. I'm gonna run a DeRale # 13700 with a fan. Which line coming out of the trans is the pressure line running to the cooler? Or does it matter? Also, because there is no room in front of the radiator for the cooler, my external cooler is going under the bed of the Luv, should I run a line to the radiator, then to the cooler then back to the trans, using both coolers? Or should I just plug up the radiator ports and use the external cooler? HELP!!!! lol Thanks in advance folks!!!
Smokey http://s294.photobucket.com/albums/m...okeyfiremedic/ |
the bottom fitting is the 'out' line of the transmission... the aux cooler must have air flow through it to function properly.
it sounds like an aux cooler with a fan on it would be better for you , than having such long runs of cooler lines front to back of the truck..
At the Bonneville Salt Flats, first gear is known as 130 mph. |
TH400 Cooler Lines
Cool, thanks for the info. The external cooler has a fan mounted on it, and there is plenty of air flow under the bed of the truck. The problem now is, I was just told that the radiator is not repairable, so now I gotta find someone who can custom build another one for me.
| TH350 Cooler Lines | Pete C | Transmission - Rearend | 2 | 04-15-2009 01:44 PM |
| trans cooler lines | eatonde | Engine | 7 | 10-17-2008 06:42 PM |
| Th350 cooler lines.... | sexypizzaman | Transmission - Rearend | 8 | 06-17-2008 11:50 PM |
| cooler lines | ragincajun19 | Transmission - Rearend | 10 | 05-01-2007 02:01 PM |
| C6 cooler lines, which is in and which is out? | MM in NM | Transmission - Rearend | 2 | 01-26-2006 09:18 PM |
