Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 direct clutch problem
Old 08-13-2012, 04:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by SaM91 View Post
Hello! I'm from Russia. I have Toyota Supra with 2JZ-GTE engine 1250 HP and TH400 transmission. It has manual shift valve body, transbreak. It was build in Coan last year, then I had rebuilded it several times. Now I have a problem - direct clutch pack often burns out. It has all Alto Red Eagle clutches. What can be the problem?
Have you checked the line pressure?
Have you had the dual feed mods done to increase the apply area of the direct clutches? It is described by Jakeshoe, beginning about 2/3 of the way down the page here.
How many frictions and steels are you using? Do you know the clearance it was set up with?
On a side note, do not put the tranny into neutral after a pass, this can overspeed the drum and scatter it and the case, etc. Don't do your burnout in low, start in second.
