Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 direct clutch problem
Old 08-13-2012, 09:55 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by SaM91 View Post
Hello! I'm from Russia. I have Toyota Supra with 2JZ-GTE engine 1250 HP and TH400 transmission. It has manual shift valve body, transbreak. It was build in Coan last year, then I had rebuilded it several times. Now I have a problem - direct clutch pack often burns out. It has all Alto Red Eagle clutches. What can be the problem?
Coan built this transmission new for you?
It would help to know what valve body design is on the trans.
Is it a "clean neutral" design trans brake ? You will have a 2nd neutral after 3rd gear. Shift pattern is P N/R 1 2 3 N
Regular trans brake shift pattern will be P R N 1 2 3
Are the stiffer return springs still in the direct drum?
Is there a bleed off hole in the direct drum? Aprox .055 diameter hole
