Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 direct clutch problem
Old 08-14-2012, 01:09 AM
SaM91 SaM91 is offline
Originally Posted by cobalt327 View Post
Have you checked the line pressure?
Have you had the dual feed mods done to increase the apply area of the direct clutches? It is described by Jakeshoe, beginning about 2/3 of the way down the page here.
How many frictions and steels are you using? Do you know the clearance it was set up with?
On a side note, do not put the tranny into neutral after a pass, this can overspeed the drum and scatter it and the case, etc. Don't do your burnout in low, start in second.
No, I had not checked line pressure, but I put in new ATI pump last rebuild. I will check pressure as soon as pressure gauge will be delivered to me
Yes, direct clutch has dual feeding.
Alto Red Eagle clutch pack: 7 clutches, 7 steels + 1 pressure plate. Clearance 0,130''. It is near minimum Alto specification clearance.
