Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 direct drum grinding on center support?
  #16 (permalink)
Old 03-09-2012, 07:37 AM
trannyguy trannyguy is offline
t400 direct drum grinding on center support
re-check your sun gear. chamfer should be down towards rear planet.installing it with chamfer up may have allowed the sun gear shaft to be down too far allowing the drum to be closer to the support.hope this helps.
