T-400 fixed yoke question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2010, 09:10 PM
I have a TH400 out of a 1987 3/4 ton suburban. The trans works well and appears to have a fixed yoke output. I'm curious if i could use this in my 81 malibu with a slip yoke type drive shaft? Also the trans has the letters HD cast into the top of the trans, does this mean anything? thank you.
Old 09-17-2010, 09:38 PM
ericnova72's Avatar
More for Less Racer
Yes, with the correct slip yoke you can do this just fine. You have to have a yoke with the first 1" or so of the splines counterbored out smooth, so the yoke doesn't bottom out on the o-ring boss on the shaft at the top of the spline that is there to seal the fixed yoke.
Old 09-17-2010, 09:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Denny drive shaft has sold the proper yoke for many years.. very easy situation to deal with
Old 09-18-2010, 12:11 AM
Thanks for the responses, greatly appreciated
Old 09-18-2010, 01:43 AM
SSedan64's Avatar
The HD cast in Case should indicate a Heavy Duty case which is thicker and has a Cast aluminum converter cover w/6 attaching bolts. There's an old thread on here w/Pics that shows the difference in the Case thickness of Bellhousing area.
More Info >> http://www.crankshaftcoalition.com/w...75.283L80HD.29
Old 09-19-2010, 02:35 AM
Wiki Edits: 85
The HD will indicate a thicker case as indicated in the above post. However, it may be drilled for an aluminum dust cover (6 large threaded holes) OR it may be drilled for a tin or plastic dust cover (4 tiny threaded holes). Other than that, there is no significant difference between it and a case without the HD on it.
such thing as a fixed yoke powerglide?? ls1camaross Transmission - Rearend 3 05-17-2011 07:19 AM
TH400 Can I replace a fixed yoke with a slip Yoke? Double_v23 Transmission - Rearend 4 08-07-2008 07:31 AM
Chevy Fixed Yoke? Triaged Transmission - Rearend 6 06-13-2008 12:43 AM
Turbo 400 yoke question...? Bumpstick Transmission - Rearend 8 12-25-2005 03:41 PM
400 yoke question TASHAN Transmission - Rearend 2 07-17-2005 09:26 AM
