T-400 full manual conversion - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 03-06-2003, 02:23 PM
New Member
Hi, does anyone know how to convert a TH400 to full manual only operation (no auto shift) without using a kit or aftermarket valve body,i.e a home made conversion.
Hi Crosley,you sound like you know a bit about auto trans,perhaps you can help? I've already done most of the heavy duty mods cheaply,I'd like to be able to hold 1st and 2nd gears 'til I want to shift,for better dragstrip performance.
I also would like the same info on the TH350 box if anyone has it .Thanks.
Quick reply to this message
Old 03-06-2003, 04:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You are talking about two different things.
Old 03-07-2003, 01:05 PM
New Member
Post
Crosley, I need a full manual shift for drag racing,I don't need any automatic features.Thanks.
Old 03-07-2003, 02:41 PM
roys63's Avatar
Post
Thats right!
Old 03-07-2003, 04:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
this will require some photos emailed around the world.
I have the photos of the 1-2 shifts mods already.
There is a hole in the valve body to drill. This loops the governor oil after you do the following:
The govermor tubes between the valve body and case should be removed and tapped with a 3/8X16 tap and threaded plugs installed. Obviously the governor can now be removed.
Leave the vacuum off the modualator. Line pressure will go up, this is fine in drag racing. In 3rd gear the line pressure will drop a bit to around 110 - 120 psi and actually help the top end charge towards the traps of the drag strip.
Or you can install a common aluminum plug in place of the vacuum modualtor and then you must remove the boost valve and PR assembly for modifications to avoid SKY high pressures in reverse.
Let me know
Old 03-08-2003, 05:27 PM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Post
Hey Tony, I'd be interested in seeing these mods myself. Been thinking of converting the TH-400 in the '28 toa full manual setup for the trail, once I get the '54 up and running for a driver...
My Email is drchop@hotmail.com or drchop@lycos.com and I usually check both eveery couple of days...
Thanks
Doc
Old 03-23-2003, 01:07 PM
New Member
Post
Crosley,the instructions you gave me worked fine,I now have a full manual TH400,thanks. Is it possible to convert the TH350 trans. to full manual in a similar way,without a kit?
Old 03-23-2003, 03:18 PM
Talking
Hey Crosley, could you also email me those mods. I would appreciate it. thanks
Old 03-23-2003, 05:47 PM
Post
Crosley, could you please post this info in the knowlege base for all, thanks.
Old 03-22-2005, 10:11 AM
Steve
Hi all, I am new here and found this old thread while searching.
Crosley is it possible to still get this information on converting a stock valve body to full manual?
I just installed a self built TH400 in my 98 TA. It shifts very nice but I would like to convert it to a forward manual valve body using the stock valve body for budget reasons.
Any information would be greatly appreciated.
Steve
Old 03-22-2005, 07:07 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
t*****************************
Steve
Old 03-23-2005, 07:06 AM
Steve
That would be great!!
My e-mail is turned on but for some reason doesn't seem to be available on the forum right now. It is, Kihco@juno.com
As for current trans mods I have done the following,
It's a 71 trans with a CR code tag.
drilled 2nd and 3rd clutch feeds in the spacer plate to 3/16",
ground a flat on the 1-2 shift valve,
plugged bleed off hole in back of valve body with 3/16" set screw,
disabled the 2-3 accumulator by blocking feed with steel ball,
shimmed front servo return spring with 1/8" spacer in case,
3 check balls,
removed center lip seal from direct clutch piston,
removed 2nd seal ring from top on center support,
forward clutch springs in direct clutch pack,
.055" pack clearance on forward and direct,.075" on intermediate.
Alto reds and kolene steels,
stronger pressure reg spring.
34 element sprag.
I'm running a 4000 9.5" stall and this is a supercharged ls1 motor.
It shifts great. But I really don't need any auto function and also would like 2nd gear starts for burnouts.
Will doing the conversion give any increased holding power in 3rd over the auto setup?
Steve
Old 03-24-2005, 06:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Did you plug the suggested hole in the separator plate or are you using an aftermarket plate. This is needed when the middle seal of the direct clutch piston is removed.
Instead of drilling a large hole for 2nd gear , leave the check ball out when a 34 elemet sprag is used.
Some separator plates have a small hole near the coasting band servo the fluid passes through for 3rd gear apply.... if it over looked the shift quality will suffer some.
I do not like kolene steels... simply a personal thing
3 check balls,
34 element sprag.
Steve
Old 03-25-2005, 08:42 AM
Steve
yes I installed a cup plug in the reverse passage near the center support bolt and am using a stock separator plate.
I attached a pic of the check ball locations and of a spacer plate showing the holes I drilled. I am using a check ball in locations 1,5 and 6. Do you recommend I remove the one in location 5?
I am not sure what you mean about the other small hole in the spacer plate that you mention. Can you point out which hole in the spacer plate pic and how I should modify it?
I am no expert on transmissions. I am just trying to learn as much as I can, so I am curious why you do not like the Kolene steels?
Thanks a ton for your help Crosley!
Steve
ID:	4377   Click image for larger version
Name:	spacer plate.jpg
Old 03-25-2005, 12:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a cup plug in tyhe case takes care of the hole I was talking about.
#5 check ball in your photo is the 2nd gear one.
Closed Thread
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Convert T-400 to a FULL manual valve body fordss Transmission - Rearend 5 04-28-2012 10:01 AM
Full Manual Turbo 400 Undo? leftyfork Transmission - Rearend 8 04-22-2011 05:54 PM
need a manual instruction for a fairbanks manual no tranbreak valve bodie th-400 betobotes Transmission - Rearend 1 09-20-2008 02:05 PM
making a full manual Big86inthestixx Transmission - Rearend 1 12-15-2003 07:18 PM
Full Manual Valve Body TH-400 Chezelle Transmission - Rearend 3 06-13-2003 06:47 PM
