Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 has delayed shift
Old 10-04-2011, 09:15 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
One common problem for a delayed shift is the vacuum line / hose that runs from the intake manifold to the vacuum modulator, unhooked or leaking vacuum.
If there is ATF present inside the line itself, the diaphragm is likely damaged, and will require replacement of the modulator.
This is, of course the "best-case scenario".
Good Luck.
