-   -   T-400 has delayed shift (http://www.hotrodders.com/forum/t-400-has-delayed-shift-206596.html)
cheese burger 10-01-2011 09:02 PM
delayed shift to second
anglia427 10-01-2011 10:58 PM
the transmission gurus could use a little more backround info on this one
cheese burger 10-04-2011 08:01 PM
th400 has delayed shift
th400 has delayed shift before i installed 2800 stall. i. have not driven the truck yet. because lost fire from distribuor and i can get the spark back.
cheese burger 10-04-2011 08:23 PM
delay shifting to 2nd and have to shift manually. just install and 2800 stall and not driven yet. because engine lost fire from distirubor
Crosley 10-04-2011 08:29 PM
cheese burger,
welcome to Hotrodders.com
I merged your multiple posts into one thread for the members to see your questions in one thread
66GMC 10-04-2011 09:15 PM
One common problem for a delayed shift is the vacuum line / hose that runs from the intake manifold to the vacuum modulator, unhooked or leaking vacuum.
If there is ATF present inside the line itself, the diaphragm is likely damaged, and will require replacement of the modulator.
This is, of course the "best-case scenario".
Good Luck.
