T-400 has delayed shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2011, 09:02 PM
delayed shift to second
Old 10-01-2011, 10:58 PM
the transmission gurus could use a little more backround info on this one
Old 10-04-2011, 08:01 PM
th400 has delayed shift
th400 has delayed shift before i installed 2800 stall. i. have not driven the truck yet. because lost fire from distribuor and i can get the spark back.
Old 10-04-2011, 08:23 PM
delay shifting to 2nd and have to shift manually. just install and 2800 stall and not driven yet. because engine lost fire from distirubor
Old 10-04-2011, 08:29 PM
Crosley's Avatar
Wiki Edits: 1659
cheese burger,
welcome to Hotrodders.com
I merged your multiple posts into one thread for the members to see your questions in one thread
Old 10-04-2011, 09:15 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
One common problem for a delayed shift is the vacuum line / hose that runs from the intake manifold to the vacuum modulator, unhooked or leaking vacuum.
If there is ATF present inside the line itself, the diaphragm is likely damaged, and will require replacement of the modulator.
This is, of course the "best-case scenario".
Good Luck.
T-400 won't shift cornfieldcars Transmission - Rearend 5 07-09-2009 04:51 AM
4l60e delayed shift into 3rd when it's cold outside stevo71 Transmission - Rearend 3 12-20-2008 06:03 PM
TH350 delayed manual 1-2 shift RocketSwede Transmission - Rearend 17 10-12-2008 12:26 AM
TH400 rebuilt delayed shift into "d" oklowride Transmission - Rearend 7 12-14-2004 09:39 PM
TH 400 shift problem BigBlock69 Transmission - Rearend 34 02-03-2004 11:43 PM
