T-400 Id - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2009, 02:40 AM
T-400 Id
Howdy folks! I have a TH400 behind the 383 stroker in my Luv and I have googled until my eyes bled (not really, but pretty darn close!) to find what it originally came out of. There is a tag on the passenger side with the following numbers: 428 across the top, then below it is
CT - 69 - 84705 Any ideas folks?
Old 01-31-2009, 03:49 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
On the LH side just above the pan there will be a partial VIN stamped into the case. It will have the code for the make, year, final assembly plant and the last six digits of the VIN of the car it was installed into.
From the final assembly plant code, and year you can determine what model was assembled at that plant at that time.
The C is for Chevrolet, the T would be the engine, 69 is the year, 8470S trans serial #
Old 01-31-2009, 04:56 AM
SSedan64's Avatar
On the THM400 the VIN is stamped on a machined surface just above the pan on the drivers side.
http://www.nastyz28.com/chevy-transm...tification.php
1967 400 with 670 heads. Trying for 400 Hp street 67pontiac400 Engine 23 07-20-2012 07:45 AM
Bolt pattern from a chevy T-400 to cadillac T-400 nthogdog Transmission - Rearend 7 03-23-2011 06:05 PM
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 06:17 PM
Olds 455 or pontiac 400/400 handymann3 Engine 48 02-03-2010 03:59 PM
pontiac 400 or chevy 400 47chevrolet Engine 2 02-02-2007 02:08 PM
