Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 intermittent squeak rattle in park and drive
Old 10-16-2012, 06:47 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Flexplate to Converter bolts are the same as TC bolts. Did you intend to say Flexplate to Crank bolts?
If the TC was wobbling the TC nose may have been rubbing the rear of the Crank. Could also cause Trans Pump, Seal & Bushing damage.
The Following User Says Thank You to SSedan64 For This Useful Post:
oldhickory (10-24-2012)
