T-400 intermittent squeak rattle in park and drive
hello everybody. i posted a question before on hotrodders, and got some awesome help. so thankful for this site.
i've got a new problem, this time with my transmission. (i think) I have an '85 chevy 3/4 ton 4x4. engine is a 402. tranny is a th400 that works great aside from being a little slow to go into reverse, and a slight leak from the the pump o-ring. (i think) Here's the problem: When i start my truck, after the temp sensor on the block hits 150 +-, i hear what can only be described as a squeak/rattle. (sounds like a spun bearing almost, but it is very 'chirpy'.) It is intermittent, and usually goes away a couple of minutes after the thermostat opens up. the sound occurs in park, while the engine is at a fast idle, and also occurs in drive while at any speed, but goes away when i increase rpm's. The sound is definitely coming from the front of the transmission as determined by the screwdriver to ear test. i call it a squeak/rattle, because it seems squeak more when going over rough patches in the road. again, the transmission seems to work fine, but the sound is getting louder, and i am beginning to notice a vibration while accelerating uphill. (no vibration apparent upon release of gas pedal.) also, the torque converter has a bit of a wobble to it, which it has had ever since i bought the truck two and a half years ago. One more thing to add: the other day it rained, and i drove in the rain, thoroughly wetting my undercarriage. The sound went away, and did not occur again for a couple of days. This caused me to think it is something external, but perhaps the humidity did something? I live in the dry desert of southern new mexico. Sorry for all the words, but i have been searching hi and lo on many forums, and am about to pull the tranny, but just thought i'd put my problem out there. I have tightened the flexplate to converter bolts, which were a little loose. i did not see any cracks. i have a suspicion that my TC bolts may be loose, thus causing the wobble? Any suggestions would be greatly appreciated.
| The Following User Says Thank You to SSedan64 For This Useful Post: | ||
oldhickory (10-24-2012) | ||
Yes, i meant flexplate to crank bolts. I decided not to pull the tranny yet, but instead replaced the filter and so far (day two) the sound has not come back. But i did find 3 or 4 very thin aluminum shavings, as well as a gray film in the bottom of the pan mixed with lots of gold colored 'dust'.
I noticed yesterday that i am missing one bolt to the bellhousing, and there is a small gap between the bellhousing and block on the passenger side (1/8"). Can this be the cause of the issues i am experiencing? |
It could be causing alignment issues. Also make sure the alignment Dowel Pins in the Block are there. 1 on each side.
All of the bellhousing bolts were quite loose, so i pulled them and replaced them with new grade 8 bolts and lock washers. It has been almost two weeks since changing the filter, and the sound has not come back. Thanks for the help guys.
| Tags |
| filter, rattle, squeak, th400, torque converter |
| car idles 1300 in park 600 in drive why? | 23 tbucket | Hotrodding Basics | 49 | 09-17-2012 07:59 AM |
| pontiac 350 idles at 1000 rpm in park 600rpm in drive | starin | Engine | 11 | 07-20-2012 06:16 AM |
| Intermittent drive and overdrive in 4L60E | tamatt79 | Transmission - Rearend | 1 | 04-24-2010 10:34 PM |
| Is this delay from park to drive a big problem on TH350? | shockers69 | Transmission - Rearend | 1 | 08-02-2004 04:27 PM |
| Engine wants to die from park to drive | Siggy_Freud | Engine | 4 | 06-03-2004 11:21 PM |
