T-400 Issues - Hunting gears and slipping? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-26-2011, 11:34 PM
SSedan64's Avatar
The 400 filter does move/flop around, they don't mount tight.
Sediment sounds about normal.
I remember reading an older Thread where Crosley said He used a spring to keep the filter pushed against the Bolt head for Offroad apps.
  #17 (permalink)
Old 01-26-2011, 11:49 PM
Good to know. Tomorrow ill finish checking things out and put it back together. I took the old fluid that came out and funneled it into two antifreeze jugs. It seems i will need 6 or 7 quarts to fill it back up.
  #18 (permalink)
Old 01-26-2011, 11:57 PM
SSedan64's Avatar
I'd reuse the old fluid, you could strain it through a Shop towel etc..
  #19 (permalink)
Old 01-27-2011, 12:52 AM
Id like too because alot of it is new fluid (that was poured into a dirty transmission) but when I drained it i drained it into a pan that had little bit of oil in the bottom of it and some dirt and leaves.I didnt get a chance to clean up the pan before I used it, i got a little ahead of myself. I had planned on keeping it so i could reuse it. oops.
  #20 (permalink)
Old 01-27-2011, 01:16 AM
Any mods i can or should do to the trans while I am in the area of the valve body and other things?
  #21 (permalink)
Old 01-28-2011, 05:43 PM
It appears that changing the fluid and filter fixed it. I am thinking that the filter had come loose from the pickup tube. It has been installed and removed while attached to the engine from 3 different trucks on several different occasions and then moved around several times while outside of a vehicle.
The lesson here I guess would be to drop the pan, clean it up and change the filter after its been out of the vehicle.
The filter element was black - but didnt have anything stuck to the filter that you could scrape off with your finger so I dont know that it was plugged. I think the filter was just barely hanging on to the pickup tube and was sucking air around it rather than sucking fluid through it.
hunting or non hunting gear ratio blownblazer Transmission - Rearend 11 09-22-2009 07:49 PM
TH-400 slipping/bad shift ... no firm shifts .. Houman SS '70 Transmission - Rearend 6 04-07-2008 01:18 AM
TH-350 slipping? TH-400 swap? aguila1 Transmission - Rearend 6 03-01-2007 07:19 AM
400 tranny slipping 49dream Transmission - Rearend 5 05-02-2005 06:58 PM
TH 400 Speedo Gears rs67ss Transmission - Rearend 5 04-03-2005 11:58 PM
