T-400 Kickdown switch help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2010, 11:31 AM
Hello all....
I have a 87 Chevy R10 with a 4.3V6 and 400 trans. I am putting in a 383 with a rebuilt 400. Can anyone tell me the location of the kickdown switch on this year truck? I have never worked with a 400 before and not sure what the switch looks like. I am not sure if it is still there.
Any help is appreciated.
Old 11-01-2010, 12:31 PM
Originally Posted by remist17
Hello all....
There isn't one. The TBI trucks controlled the TH400 kickdown from the ECU by reading the throttle position sensor. I assume you're dumping the computer so you'll need to rig a kickdown switch from an earlier TH400 truck. Any 1986-earlier full size pickup with TH400 should have the switch on the accelerator pedal.
Old 11-01-2010, 01:18 PM
thanks for the confirmation on computer and yes no computer. Any one have some photos of the switch on the pedal so Iknow what I am looking for in the junkyard?
Old 11-01-2010, 01:55 PM
The switch looks like this, though the truck bracket may be different. Just look at the accelerator pedal where it bolts to the firewall under the dash. The switch will be right above the pedal. Any 1986-earlier truck with a TH400 will have one.
Old 11-02-2010, 07:50 AM
Going ot order the B&M switch from Summit and fab a bracket to the gas pedal. Anyone do this before?
Old 11-03-2010, 05:51 AM
Just a couple of other suggestions
Yogi's has a Lokar kickdown for the TH400 with no fab needed. It sells for around $70. Or...you could just wire a switch to activate the kickdown and save a bunch. Just my $.02
Barry
Old 11-03-2010, 11:19 AM
any suggestions on installation and how to's?
Order from summit the B&M for 35 bucks.
Old 11-03-2010, 11:31 AM
With just a little fabrication ... you can have a neat, functional 400 kick down switch.
This is the one on my 32 Ford roadster. There is not enough room in/around the firewall/floorboard area for a foot operated switch. The older Chevrolets and Buick used a accelerator activated switch so I just made a little bracket and fixed a small switch to work on the 400 Turbo in my 32 Ford/with SBC.
The Following User Says Thank You to Deuce For This Useful Post:
Juleshulings (03-05-2013)
Old 11-03-2010, 12:22 PM
Of course that's a viable option, but I'm lazy and with no fabrication one can bolt on factory parts for a C/K truck.
Old 11-03-2010, 04:01 PM
True, so true ...
But maybe not everyone looking at this thread has a C/K truck.
A LOT of vehicles just do not have the room for a factory type C/K switch.
Most early street rods ... do not.
I also realize that most early street rods have gone to using the automatic overdrive transmissions ...
not the older Turbo 400's. I have the 700R4 in my 32 3W.
Old 11-03-2010, 08:51 PM
junior stocker's Avatar
B and M sells an IDENTICAL setup to take the DIY and fab out of you hands.
Old 11-03-2010, 09:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Earlier in my life span , I used the brake lite switches off motorcycles , when they had the pull type switch with a spring attached to them
Old 11-04-2010, 08:40 AM
appreciate the help all.
Anyone out there have a installed gas pedal installation? Looking for all the options.
I am thinking a small modification to a old bracket I have could work on the carb realitvely easy.
Does the pull chord need to attach to the same place the throttle cable goes? I am running a Jegs billet throttle linkage setup were the stock throttle cable attaches. I am thinking I can mount a braket below this and run the spring up to the point on the carb.
T-400 kickdown switch krunch007 Transmission - Rearend 4 09-12-2012 05:15 AM
T-400 Kickdown switch location ? Tank Killer Transmission - Rearend 1 01-03-2012 04:03 AM
looking for a kickdown switch dawg Transmission - Rearend 1 07-01-2007 07:08 PM
kickdown switch Blown79 Transmission - Rearend 2 08-31-2004 07:24 AM
kickdown switch Blown79 Engine 3 08-30-2004 07:38 PM
