-   -   T-400: leaks and leaks and more leaks (http://www.hotrodders.com/forum/t-400-leaks-leaks-more-leaks-224555.html)
Lthompson 10-01-2012 03:13 PM
Got a turbo 400. Bought it new. Its a tci street fighter i believe. But it has leaked from day one. Had the pan off several times. Got it to almost quit. Not near as bad as it was anyway. But the worst leak is where the tailshaft bolts to the main body. 4 bolts there and they are dog tight. Doesnt leak out the end of the tailshaft. What is it going to take to fix it? thanks
RWENUTS 10-01-2012 03:51 PM
Is the vent in the top passenger side open.
Here's a pic.
http://www.hotrodders.com/forum/does...ed-218740.html
Crosley 10-01-2012 05:54 PM
Welcome back, you have not posted in a while
The tail shaft housing on a T-400 has 6 bolts. Perhaps 2 are loose?
Lthompson 10-02-2012 02:56 PM
ive tried tightening them. They seem dang tight already
Crosley 10-02-2012 09:50 PM
You might try 2 gaskets and some good adhesive on the tail housing to stop the leaks.
Lthompson 10-04-2012 02:50 PM
figured out most of my leak is coming from where the speedo cable screws on. its running down and dripping off where the tailshaft bolts on. Does the cable has some sort of o-ring i the plug or something to keep it from leaking there? i need a new one anyway. And the pan is still leaking around it too. And its leaking a little out the rear seal. But the worst is from the speedo cable
SSedan64 10-04-2012 03:08 PM
Yes, there's an inner Seal and outer O-ring.
#078 & #369 >> https://www.wittrans.com/Schematic.a...00&Schematic=4
Lthompson 10-05-2012 06:24 AM
was able to tighten the cable some. But its also leaking out of the gear housing. I put it in there but i dont remember if the housing screws in or just slides in and the retaining fork thing keeps it in. Didnt want to try turning it to tighten and mess something up. What do i need to fix this? thanks
