The tail shaft housing on a T-400 has 6 bolts. Perhaps 2 are loose?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
You might try 2 gaskets and some good adhesive on the tail housing to stop the leaks.
figured out most of my leak is coming from where the speedo cable screws on. its running down and dripping off where the tailshaft bolts on. Does the cable has some sort of o-ring i the plug or something to keep it from leaking there? i need a new one anyway. And the pan is still leaking around it too. And its leaking a little out the rear seal. But the worst is from the speedo cable
Yes, there's an inner Seal and outer O-ring.
#078 & #369 >> https://www.wittrans.com/Schematic.a...00&Schematic=4 |
was able to tighten the cable some. But its also leaking out of the gear housing. I put it in there but i dont remember if the housing screws in or just slides in and the retaining fork thing keeps it in. Didnt want to try turning it to tighten and mess something up. What do i need to fix this? thanks
| Turbo 400. Leaks/Drive Shaft Play. | hunk-a-junk | Transmission - Rearend | 2 | 10-01-2008 04:43 PM |
| vacuum leaks | JG700 | Engine | 9 | 06-25-2007 06:38 PM |
| T-400 leaks real bad. | GEARHEADWV | Transmission - Rearend | 5 | 03-19-2007 08:12 PM |
| c4 leaks | 57custom | Transmission - Rearend | 2 | 04-29-2004 10:46 PM |
| Turbo 400 leaks into transfer case | latheman | Transmission - Rearend | 2 | 02-13-2004 06:09 PM |
