T-400 leaks real bad. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2007, 10:02 AM
I just pulled the 400 turbo back out of the car. It looks like it is leaking from every possible place it could! I had a guy rebuild it probably 2 years ago but it dont have 300 miles on it since the rebuild. I know it shouldnt leak at all but a little leak i could deal with, but it acts like its building preasure and coming out everywhere. What can i look for. How can u tell if the vent on top is clogged? Also the tranny didnt have a dipstick and i put the one out of the 700r that was in the car to start with. Is this dipstick the same as a 400's? or is it causing me to over fill the trans. It looks as if its leaking at the linkage port, Speed od. port, the pan, maybe a very little out of the front pump seal. The car is a 84 monte ss, ~450 hp 350, 3800 ati stall, and of course 400t tranny. The 400t come out of a mid 70s 3/4 ton chevy truck. Thanks for any help.
Old 03-17-2007, 03:35 PM
The vent isnt stopped up, Id on the side is 76-CP 31178.
Old 03-18-2007, 07:09 PM
How hard is it to change these seals? At the linkage, speedod. Do they go from the inside, or outside?
Old 03-18-2007, 07:27 PM
71 c-10's Avatar
just a kid and his truck
Speedo should be an O ring, the shifter you will need a special tool that grabs the seal and will pull it right out, its like a hallow bolt with kinda sharp threads
Old 03-18-2007, 10:11 PM
Simple tool to remove and reinstall the shift lever seal ... KD #2393
About 10 dollars at most decent auto parts stores ... works great.
Deuce ... Moderator
Old 03-19-2007, 08:12 PM
71 c-10's Avatar
^^^^ exactly
Turbo 400 leaks into transfer case latheman Transmission - Rearend 2 02-13-2004 06:09 PM
De-stroke 400 mouse or not? 54Guy Engine 8 08-02-2002 06:49 PM
Need timing advice real bad 54 Chevy Engine 4 07-25-2002 07:09 PM
I need help......real bad TOTALNOVICE Engine 8 06-29-2002 08:09 PM
need advice bad! 400 small block irocan Engine 0 02-10-2002 04:17 AM
