Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - T-400 locked up
Thread: T-400 locked up
Old 10-22-2012, 06:04 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Sometimes bearings wear out for no direct cause. I would suggest the thrust washers, bushings and bearing all be replaced in the gear train.
Check clearances and check for wear. Look at the planetary pinion pins for movement forward and backwards. When the pins move , they wear into the thrust washer
