-   -   T-400 locked up (http://www.hotrodders.com/forum/t-400-locked-up-225234.html)
81496camaro 10-21-2012 11:40 AM
T-400 locked up
Take apart transmission and found the torrington bearing between the reaction carrie and sun gear is munched up. All other bearings and internal parts look good. What would cause this?
81496camaro 10-21-2012 07:20 PM
Th400 locked up
I'm a newbie to this site. Anyone with some info about my transmission problem please help.
Thank you,
Art
Crosley 10-22-2012 06:04 AM
Sometimes bearings wear out for no direct cause. I would suggest the thrust washers, bushings and bearing all be replaced in the gear train.
Check clearances and check for wear. Look at the planetary pinion pins for movement forward and backwards. When the pins move , they wear into the thrust washer
81496camaro 10-22-2012 10:05 AM
Thanks for the reply.
