T-400 locked up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2012, 12:40 PM
T-400 locked up
Take apart transmission and found the torrington bearing between the reaction carrie and sun gear is munched up. All other bearings and internal parts look good. What would cause this?
Old 10-21-2012, 08:20 PM
Th400 locked up
I'm a newbie to this site. Anyone with some info about my transmission problem please help.
Thank you,
Art
Old 10-22-2012, 07:04 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sometimes bearings wear out for no direct cause. I would suggest the thrust washers, bushings and bearing all be replaced in the gear train.
Check clearances and check for wear. Look at the planetary pinion pins for movement forward and backwards. When the pins move , they wear into the thrust washer
Old 10-22-2012, 11:05 AM
Thanks for the reply.
Locked radio deadbodyman Electrical 6 06-03-2009 05:56 AM
Locked Out......Yet Again malc Hotrodders Site Suggestions and Help 8 05-07-2008 11:09 AM
Radio Locked Out?? lwin517 Electrical 2 11-29-2007 02:58 AM
Locked out? BstMech Hotrodders' Lounge 2 02-03-2003 06:45 PM
