T-400-to LS3 ENG - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 06:55 PM
T-400-to LS3 ENG
Can I Bolt A T-400 To A New Ls3 Eng.
Old 03-10-2011, 05:27 AM
I believe so... should be your average chevy bellhousing pattern.
Old 03-10-2011, 06:08 AM
ericnova72's Avatar
More for Less Racer
Yes, but one bolt hole on the trans case will not have a place on the LS block. It is the one behind and below the passenger side head, the one the dipstick tube is usually also anchored to. The LS has no bolt hole in this spot.
The LS rear block face is also a different depth, it is shorter than a Gen 1 SBC, so it needs an extension adapter between the crank and flexplate/flywheel if I remember correctly.
Old 03-10-2011, 09:20 AM
S10xGN's Avatar
Gotta love a turbo!
There are a bunch of posts on LS1Tech about doing this, GM has a flexplate/spacer package out now that's cheaper than either piece bought separately.
Russ
help with my eng # mike lost in cars Engine 5 10-18-2012 10:28 PM
4.3 Marine Eng To A 350 Chev Eng DAN CASPER Engine 2 07-19-2010 07:56 PM
350 heads on 400 eng. by mistake retired 56 Engine 7 05-22-2007 12:19 PM
5.0 86 eng to a 74 c-4 FEDDO Transmission - Rearend 4 03-08-2005 10:03 PM
400 eng w/350 crank what starter &flexplate? in2classx Engine 2 12-17-2001 07:09 PM
