T-400 manual valve body 2-3 shift? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2012, 04:48 PM
Here's to my trans guys.
Blown SBC, 3500 Pro Torque Converter, TH400, 9 inch rear.
Recently had a manual forward valve body installed. 1-2 shifts are firm; however, 2-3 not so good. I shift to 3rd and have to throttle down to get 3rd to engage? I checked the shifter cable-to linkage...all good. The valve body install required the modulator valve to be ground at the modulator end in two spots 180 degrees apart and the modulator reinstalled. I currently do not have a vacuum line running to the modulator. Lets hear what you think.
As it may come up, I went to a manual valve body because of the blower and a forward pattern because the shifter was currently in the vehicle. It is a street car.
Old 07-28-2012, 10:05 AM
I had basiclly the same setup. I ran a vacuum line and worked fine.
Old 07-28-2012, 02:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
With no vacuum to the modulator , the main line pressure is higher.
History on this T-400 ?
Stock rebuild? Was the direct clutch drum setup for dual feed?
What brand of T-400 manual shift valve body was used... or what ''kit'' was used to convert the valve body?
The flat spots on modulator valve , sounds like the mod for no pressure cut back from governor pressure as road speed increases
Old 07-28-2012, 03:50 PM
It was in the car when I got it.
Old 07-28-2012, 05:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
My questions are for Classick53 since this is his thread
Old 07-28-2012, 05:30 PM
Trans was built for the engine & rear end configuration. Unfortunately I do not know the details of the build. Hughes forward pattern full manual v-body.
Old 07-28-2012, 11:41 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The Hughes full manual forward valve body dual feeds the direct clutch drum through the separator plate. Not as good a method as having the trans built with dual feed internally.
Also i wonder how the trans was built internally on the direct clutch drum frictions. Some builders install a wave plate in the direct clutch drum, this will soften the 2-3 shift
Old 07-29-2012, 07:42 AM
It's not that my 2-3 shift is soft, it doesn't engage until I let off the pedal. It gets better...yesterday took the truck out a couple of miles and when I put it back into the garage...reverse doesn't fully engage until you throttle up. This trans probably has 150 miles on it.
Old 07-29-2012, 10:36 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The direct clutch operates in reverse and 3rd gear. Since you have a problem in both, I suspect a problem with pressure loss in the center support , sealing rings or the drum it's self
TH350-TCI manual shift valve body questions.... Coletrane Transmission - Rearend 2 04-23-2010 06:39 AM
Shift kit or manual valve body??? OneMoreTime Transmission - Rearend 6 03-08-2008 04:19 PM
Turbo 400 Manual valve body Tbucit Transmission - Rearend 3 05-10-2006 10:30 PM
auto shift kit in manual valve body? cadillacart Transmission - Rearend 0 01-11-2004 10:03 PM
Full Manual Valve Body TH-400 Chezelle Transmission - Rearend 3 06-13-2003 07:47 PM
