T-400 Modulator or Governor Upshift? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2010, 12:24 AM
454headache's Avatar
At full throttle my turbo 400 upshifts at 4,500 rpm. I want it to upshift at at least 5,000, maybe even 5,500. I know that the modulator controls upshifts, but only up to WOT I think. After that, the springs in the Governor decide when to upshift right?
So should I get different springs for the governor or adjust the modulator? If I adjust the modulator won't all upshifts be higher up in the rpm range? I mean, If say I adjust it to 5,500 WOT upshift, won't my partial/cruising throttle upshifts also be up much higher?
Old 03-30-2010, 01:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
An adjustable modulator might get you an extra 5-6 MPH at WOT, less (maybe 2-3 MPH) at cruise speeds.
The way to get higher WOT shifts with the shifter in "D" is by modifying the GOVERNOR.
You can also do an easy mod to the 1-2 shift valve to allow you to hold first until you manually shift to second. But be aware that it also allows downshifts at ANY speed. The way it is stock, if you pull the shifter into second from "D" at 100 MPH- nothing will happen until the road speed drops to low enough for second gear to engage.
Old 03-30-2010, 07:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Your understanding of the modulator and governor operations is incorrect.
The governor weights and springs work together
The springs in the governor control shift points primarily at light throttle. Changes to the springs affect shift points more up to 35 mph area depending on gear ratio - tires ,etc.
The weights affect higher speed shift points more than the springs do.
Later WOT shift = higher RPM will happen by lightening the weights ( inner) on the governor.
The vacuum modulator affects mostly th e light throttle shift points. At WOT the vacuum will be near zero and the modulator will be ineffective. This will have main line pressure raised.
I would suggest you prchase a kit with different weights and springs to modify your governor. Or simply start grinding on the inner weights for later WOT shift points.
The lighter weights will affect light throttle shifts slightly on the t-400 trans , but mostly the higher speed shift points
Old 03-30-2010, 01:20 PM
So to grind down the weights, you just remove the gov cover, and they come out? How much to grind to raise the shift point about 1,000 rpm?
Old 04-05-2010, 11:29 PM
Best cheap mod ever. I spent a half hour jacking up the truck and grinding on the inner weights, bought a box of 6D nails to replace the pins, and now I have great WOT at 5,500.
Old 04-06-2010, 05:48 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Good to see you have adjusted the shift points and you learned a little bit too
T-350 governor/modulator? sabino56 Transmission - Rearend 9 10-11-2013 07:25 PM
T-400 - No Manual Upshift Mr. Fixit Transmission - Rearend 1 11-21-2011 12:54 PM
th 400 1-2 upshift w/lever in 1st grayghost52 Transmission - Rearend 3 07-05-2011 10:38 AM
T-400 governor gear breaks off 63droptopnova Transmission - Rearend 7 05-30-2007 07:10 PM
th400 won't upshift...not modulator msc66 Transmission - Rearend 1 08-28-2005 10:58 PM
